nowadays they just steal the black plastic ones off my car because.. why not. ugh.When we were kids we would steal those fancy chrome ones for our bikes, because they looked cool.![]()
That's what mine are. Chrome plated brass.I've used chrome plated brass valve stem caps on all of my vehicles for years and have never had a problem. I typically use the German style and have been known to use a dab of silicone on the threads of my DD's wheels.
So one of my friends bought a Bonanza and we have been laughing at the absurdity of plane parts prices. Dare I even ask how much these are?The aviation style valve caps MS20813-1 are what you seek. Brass, corrosion proof and don't stick. Plus they will absolutely hold back 3000PSI and are rated to 5000PSI.
Enough that you'd be mad/sad whenever they got swapped out.So one of my friends bought a Bonanza and we have been laughing at the absurdity of plane parts prices. Dare I even ask how much these are?
I'll keep mine. Dill 637 on everything.Just in case you haven't experienced the joy of removing a metal valve stem cap that has fused itself to the stem through galvanic corrosion, here's your reminder that you need to replace them with plastic ones. The RAV4 I bought last fall had them on three wheels and all three needed vice grips to remove.
I just bought another 25 pack on eBay.The aviation style valve caps MS20813-1 are what you seek. Brass, corrosion proof and don't stick. Plus they will absolutely hold back 3000PSI and are rated to 5000PSI.
My BMW came with these stainless steel caps 25 years ago...never been a problem removing them.
https://www.fcpeuro.com/products/bmw-valve-caps-36121120779
Just warm it up a little first. Daughter-in-laws old Accord had them. Right front hadn't been checked in who knows how long and was visually very low. Yup needed pliers on that one. First time she came over I was likeand the rest that did come off, her grandfather put to 51psi since that was "sidewall" pressure.
Replaced them all with plastic and pressure to door placard all around. Her comment "the car rides so much better".
Like Jimmy Buffet sang - "If we couldn't laugh we'd all go insane".Thanks for thelaugh.
Check the air pressure more often and the caps won't seize.Just in case you haven't experienced the joy of removing a metal valve stem cap that has fused itself to the stem through galvanic corrosion, here's your reminder that you need to replace them with plastic ones. The RAV4 I bought last fall had them on three wheels and all three needed vice grips to remove.
........ Dare I even ask how much these are?
