Metal valve stem caps-throw them all away
Elkins45
Site Donor 2026
Northern KY
Just in case you haven't experienced the joy of removing a metal valve stem cap that has fused itself to the stem through galvanic corrosion, here's your reminder that you need to replace them with plastic ones. The RAV4 I bought last fall had them on three wheels and all three needed vice grips to remove.
Just warm it up a little first. Daughter-in-laws old Accord had them. Right front hadn't been checked in who knows how long and was visually very low. Yup needed pliers on that one. First time she came over I was like :eek: and the rest that did come off, her grandfather put to 51psi since that was "sidewall" pressure.
Replaced them all with plastic and pressure to door placard all around. Her comment "the car rides so much better".
Wierd. I live in the rust belt with heavy use of salt in the winter and I do not ever experience metal caps seizing on. Never been an issue. I maintain five vehicles. The metal caps I use are the thin knurled ones.
The Porsche company in Stuttgart ALWAYS replaced mine with plastic ones / ALWAYS /
No matter for what reason I went there, when I picked up the car, there were plastic caps on the valves /
For normal they didn't even mention it.... /
At this time galvanic corrosion was the last thing I had in mind / ;)
Only when our TPMS batteries are dead.
Fancy you with your RAV4 that has functional TPMS :). My 2020, it only warns if tire when it is significantly low; like 6+ PSI low. For my 2020 they opted to not have a display that shows the actual pressures and instead opted for you having to use the app to see your pressures. Problem is, that unless you opt in to selling your vehicle telemetry data to 655+ “trusted third parties”, you can’t use the app. So I check my pressures every other weekend or so.
I had a pot metal hose nozzle weld itself to the male end of a hose after leaving it attached for several years. I ended up having to cut it off with a cutoff wheel attached to an air grinder.
Yep, got some water hoses that did that - now I pay more attention when I buy new … Plastic quick connectors …
I've used chrome plated brass valve stem caps on all of my vehicles for years and have never had a problem. I typically use the German style and have been known to use a dab of silicone on the threads of my DD's wheels.
