all of a sudden I got poor idle, it was impossible to idle, it would die. I pulled the codes, it had P0106 if I remember correctly. A quick search said it 's the MAP sensor on top of EGR. Swapped that and to no avail.
Got my mechanic involved, he on a hunch pulled compression readings and at least one cylinder, #2 had zero compression. The one next to it pulled good numbers. So it's basically a parts car. 190K miles. 2007 model year.
Is that normal for 4.0L engine? It never overheated although when I looked the coolant was about 3/4 of a gallon low.
What would cause cyl #2 to have zero compression?
