mercon v dilema
chad8, $59 to do a complete fluid exchange is a very low price...too low, in fact, and that makes me suspicious. I've never heard of anyone charging less than ~$100 for this service.
Another thing: at only 26,000 miles you really don't *need* a complete flush. A pan-drop on a Taurus changes approx 7 quarts so you're replacing ~50% of the fluid. Use real Mercon V and do it yourself and you'll be fine.
The transmission fluid is easy to flush on the Taurus at home. It only takes a five gallon bucket and the 15 quarts of fluid. If you want to drop the pan and change the filter that is not hard either but with you relatively low mileage I would wait.
This is a modified procedure that is in the Ford service manuals.
Here's the easiest and cleanest way to change the ALL the fluid and filter.
1. You may still spill some fluid when dropping the pan. Best just spread out the oil dry before starting.
2. Jack up the car and place on jack stands.
3. Next disconnect the line on the drivers side of the aux ATX cooler. Put the transmission side line in a five gallon bucket. Attach a piece of 3/8" hose to the cooler where you just disconnected the line and place it on the bucket.
4. Start the engine and wait until the fluid almost stops. There will be a definite difference in the amount flowing out.
5. Stop the engine.
6. Start loosening the bolts on the pan. There is still 3-4 quarts in the pan. Position a drain pan under the transmission pan and on the drivers side. Loosen and remove all the bolts but two on the passenger side. This will let the drivers side tip down as you then slowly loosen the remaining two. After the pan is mostly down and the fluid is in the drain pan remove the pan completely and replace the filter. Be sure to remove the rubber ring that will stick up in the transmission filter mount. Just bend it in with a screwdriver and pull it out with a needle nose. Do not scratch the aluminum transmission filter holding housing.
7. Reusing the OEM gasket and in a three pass sequence progressively tighten every other bolt until all are tightened. Do not over tighten as they really just need to be snug. Use a 1/4" ratchet drive socket.
8. Then add 10 quarts. Start the motor and wait until it almost stops pumping fluid out or until you see new fluid coming out. Better to waste a quart or two of new fluid to insure all the old stuff is out.
9. When the flow has almost stopped, shut off the engine and reconnect the hoses.
10. Add 5 quarts, idle motor and check level keeping it on the low side on the dipstick.
11. Then drive the car for a while to heat up the transmission fluid and recheck and top off the fluid.
The pan gasket is reusable if it is the OEM rubber one. Total system capacity is around 14-15 quarts. Buy a couple of extra quarts to get all the old stuff out.
So my $59 exchange turns into over $100 do it myself project ? Can any of you recommend a place to get mercon v for a reasonable price? It sure sounds like y'all like to spend opm.
You can get Supertech Mercon V for less than $4.00 qt. If you are just dropping the pan and changing the filter you should only need about 6 qts max.
