What is the difference between Mercon V and MV??
Is really conduse. I thought that was the same but apparently are differents. A call the Mazda dealer (I am from Central America) al I asked for the ATF for Mazda 6. They Told me that they use the MERCON V, not the MV. They told me that are the same but I read that are differents.
Impossible to get the MV here. I had to bought the Mercon V, but by mistake I replace some months ago for a normal ATF, because in the Manual are a Mazda 6 2wd and 4wd, I use the one that use the 4WD and the normal that you can get here everywhere. Bean the problem with tha transmission, shift.
This appear in a Service Boletin from Mazda:
Subject:
CORRECT APPLICATIONS FOR ATF M-V (TYPE M5) AND MERCON®V AUTOMATIC
TRANSMISSION FLUIDS
Bulletin No: 05-005/08
Last Issued: 4/11/2008
Service Bulletin Mazda North American Operations
Irvine, CA 92618-2922
MULTI MODEL - CORRECT APPLICATIONS FOR ATF M-V (TYP
DESCRIPTION
Always be sure to use the correct automatic transmission fluid when replacing ATF. Using the wrong ATF may
cause shift quality complaints or may even damage the transmission.
NOTE:
• ATF M-V (TYPE M5) IS NOT THE SAME FLUID AS MERCON®V ATF.
• ATF M-V (TYPE M5) HAS A GREATER VISCOSITY THAN MERCON®V ATF IN LOW TEMPERATURES.
• ATF M-V (TYPE M5) HAS A GREATER ANTI-JUDDER SPECIFICATION THAN MERCON®V ATF.
CAUTION:
• USING ATF OTHER THAN ATF M-V (TYPE M5) IN AUTOMATIC TRANSMISSIONS
DESIGNED TO USE ATF M-V (TYPE M5) MAY CAUSE SHIFT QUALITY COMPLAINTS.
• USING ATF OTHER THAN MERCON®V IN AUTOMATIC TRANSMISSIONS DESIGNED TO
USE MERCON®V MAY CAUSE TRANSMISSION DAMAGE.
Subject:
TRANSMISSION FLUIDS
DESCRIPTION
NOTE:
CAUTION:
