- Joined
- Dec 27, 2020
- Messages
- 2
I have a 2006 Ford Explorer with a 5r55s sealed transmission. I was changing my transmission fluid because it hadn’t been done in a long time I went to autozone or to get the fluid and this guy brings out 5 quarts, looks like V to me but after I pump everything I look at the bottles and see 3 were mercon V, one was import (type Z) and one was LV. All the import and about half a quart of the LV is in the transmission. I had ran the transmission to check the fluid level and I hadn’t filled it enough but not a single gear engaged, but that’s most likely a fluid level issue. I took out that drain bolt but nothing came out I’m going to add about 5 more quarts of MV. Is having small amounts of LV gonna destroy my transmission or am I good to fill it and hope for the best
