Originally Posted by RF Overlord
To add fuel to this fire, Valvoline does not sell a "Mercon V" specific product. Their product is called "ATF for Mercon V Applications" and the web site even states that it is neither licensed nor approved by Ford. I'll continue to use Motorcraft, Castrol, or SuperTech, all of which ARE licensed and approved by Ford.
I just performed the 3X drain & fill procedure with Valvoline MaxLife ATF on a Ford 6F35 transmission. I'll let you know if it blows up.
Next up will be a fluid exchange on a Ford 4R75E transmission.
Funny thing about those Ford transmissions is that members on Ford vehicle forums all swear that you can only use MotorCraft fluid. Same members who also have problems with their Ford transmissions.
Over the years, I've used a lot of different brands of automotive fluid. If the transmission fluid is really that bad, the transmission should start to fail immediately, as you're adding the fluid. All transmissions experience wear. I don't think any brand of fluid accelerates the wear. Most transmission failures would have happened no matter which fluid you used. Look at all of those vehicles which were only dealer serviced, and everything was done by the book. They have transmission failures also.
