Originally Posted By: 1JZ_E46
Originally Posted By: CleverUserName
Originally Posted By: edyvw
No, but he did do two UOA.
Yes I did two UOAs and also there is another series of UOAs from a 2014 Chevy Cruze using Amsoil Low Saps and Biosyn CJ-4 posted on here somewhere. They had similar wear numbers, however the Biosyn handled water and fuel contamination much better and there was no bearing wear, unlike the Amsoil which did have some soft metals detected in the UOA. Dealing with oil contamination seems to be one of the major strengths of the Biosyn formula.
Neither the Amsoil or the Biosyn are Dexos 2 certified. Just like Delvac ESP.
I just can’t understand why you’d throw away a manufacturer’s warranty because you have such an unwarranted distaste for C3 oils. Why risk paying for a DPF or something like that out of pocket? Those are expensive parts.
Based on his wear number I think once he moved to HDDO he gained at least 60hp, increased life of an engine by at least 100,000 miles and increased mpg by 3-4
He actually took seriously my comment about two UOA.
