Originally Posted By: Shannow
Originally Posted By: mjoekingz28
I DO NOT appreciate this line of thinking. Please keep it to yourself. And go ahead and tell Fram racing that their filters have no place, since as you said, the engine is not going to care about a restrictive oil filter........
OK, so you disagree and tell the poster to keep quiet ?
As a self proclaimed seeker of the truth, do you honestly believe that a few psi difference (if that) in filter DP is going to have a material effect on the engine ?
A Fram "racing oil filter" (or similar) might give a few more PSI and therefore a little more flow to the engine at red line IF the oil pump was in pressure relief. A filter like that would help out in situations where a highly modified engine has some crazy insane oil pump that put out way more flow volume than a stock oil pump.
So, mjoe ... my comment was about normal vehicles on the road, not some super modified race engine. 99.999% of the stock cars on the road can't even make the oil pump go into pressure relief mode at redline when the oil is at full temperature - I couldn't on my Z06 (which is pretty high performance in stock form) no matter what oil filter I was using. I bet if I put some crazy aftermarket oil pump on it, then that might change.
