Donaldson Small Engine Filter Media P502024
So the 551132 filter doesn't have an ADBV? At least the Fram XG has that. Lol
Sure it does.
Sure it does.
I see now that it does, albeit nitrite instead of silicon. I was going by gasman’s comment, I did not read the article.
What is the main advantage of silicon over nitrile in an ADBV? Better heat resistance? Will the nitrile buckle & allow back flow?
Agreed. I don't know if the Deere Kohler/B&S engine needs and anti drainback valve or not, but that seemingly is the only "drawback" I can find (after ordering several) with the P551132 filter.
@garageman402 you're right, it indeed DOES have the ADBV. I looked just now on Donaldson's website to confirm. I guess where I ordered it from had incorrect details. Which is a win!
EDIT: for some reason I got my filter part numbers crossed and P169071 is what does NOT have the ADBV.
Yes, better heat resistance, it won't get hard with heat like nitrile rubber could. Also more flexible when cold. The nitrile won't "buckle", but could get hard and then not seal well like an ADBV should.
The P169071 definitely has an ADBV (black circle in the picture):
