- Joined
- Sep 26, 2010
- Messages
- 9,835
I just dumped the factory fill in the Explorer a bit ago (1,905 miles on it) and refilled with some Mobil Super 5000 5w20 for a short OCI to 5K and then will likely switch to Kendall to see how it likes it.
One thing I noticed was the OEM filter was quite a bit longer than the FL-500s that is specified in the owner's manual. It caused me to double check the OM to ensure I had the right filter. I am hoping that BDCardinal or one of the Ford guys will chime in and give a clue why this is. It made me wonder if Ford installed a different filter at the factory. I saved the OEM so that I can compare to the retail FL-500s that I will dissect when I change it again.
Pleats were nice and tight and construction was very good (as expected). The only thing I did not like was there is a heat shield that has to be removed to gain access to the drain plug. The filter was very easy to access and install (it is mounted in a vertical position). At any rate enjoy!
