Terry,
When I talked to Amsoil tech services about this application several weeks ago, they recommended their CI-4/SL rated 10w-40, instead of the newer Series 2000, 0w-30 stuff. I thought that was interesting ....
The MB list of "Approved Oils" has always been more of a "buy in" than anything else - in the past you had to pay to get on this list. I don't give it any special significance, even though several Amsoil products are on the DB 229.3 list. You also have to keep in mind that even the MB V-6 engine holds 7.9 quarts of oil and the V-8s hold even more, so running long drains in these cases isn't very demanding. I'd bet that the garden variety Mobil 1, 10w-30 would last for at least 25,000 miles in these motors.
The primary reason why they are recommending 0w-40 instead of 5w-40/10w-40 is that the low temp pumpability tends to degrade faster than the high temp properties. So at the end of one of these long drains, the 0w-40 would test out to be approx a 15w-50 grade, due to oxidative thickening and nitration. Anybody who works in the industry understand that ....
TS
