- Joined
- Aug 16, 2021
- Messages
- 27
hello ,we are a group of mazda 3,6,cx 3,5,30 owners live in extreme hot , dusty environment with an average temperature 109 °F.
and the owner manual doesn't have any hot countries and we have few questions after i have read alot of discussions
1- we compared ATFs and found that mz-fz is fully synthatic made by idemitsu indonesia , toyota ws is meniral oil have group 3,4,5 , louqi moly 1800 are semilar to mazda fz but half priced and semi synthetic , dexron vi and KIXX ATF DX-VI are a bit thicker , quarter of the price and fully synthetic can we mix mz-fz with dexron vi , and when to drain and fil ? all data sheets are here Google Translate
2- are catch can necessary if we use 0w20, 5w30 api sp , sn + , low sulfer , because on our experience with 43500miles , 25 miles car there is minimal carbon build up on cylinder valve maybe of the heat?
3- regarding bulit in mazda oil/air seperator under pcv when to clean them and how , what did mazda change after this article because my car is 2.0 2015 Mazda CX-9
3- when to chenge transmision coolar because there is a website recommend to change it every 4-5 years Google Translate 4- when to change break fluid in in dry environment because i haven't found an accurate tester
5- will cleaning maf , oxygen synsor with maf cleaner damage it , what is the recommended interval ?
6- fl22 and motorcraft vc10a2 are semilar , and motorcrafet said " Motorcraft® Yellow Antifreeze/Coolant can be used to top-off or entirely replace (drain and refill) antifreeze/coolant in vehicles factory-filled with Motorcraft® Specialty Green Engine Coolant. https://www.fcsdchemicalsandlubricants.com/quickref/FCSD Motorcraft Yellow Antifreeze-Coolant Backward Compatability.pdf , but in the 2021 ford SDS the yellow has 2-eha
is it better than fl22?,, can we dilute it with 35/65 distilled watter to increase heat exchange (in 0.951 quart Measuring Cup , 0.62 quarts premix , 0.33 quarts distilled water
7- what do think of this schedule :
each 5.6k miles or 6 months : engine oil and filter , clean engine air filter by hitting it only , clean engine air box with air gun while closing maf inlet , injector cleaner , clean radiator from the back to front with air gun ,
each 11.2k miles : cabin filter , tyer rotation
each 18.6k miles : replace engine air filter
each 24.8 : break fluid synthetic dot 4
each 37.3 or 43.5 : drain and fill transmission fluid with filter , fuel filter PE11-13-ZE0 and PE01-13-ZE1
each 62k miles : coolant flush , both engine belt and tensioner , pour catalytic converter cleaner in oxygen sensor inlet , spark plugs , clean maf , manual cleaning with brush valve, intake , intake manifold with there specific cleaner ,, throttle body
each 124 miles water pump and thermostat and radiator cap
thanks and we really appreciate your help
