2009 Kia Sedona - Maintenance and Repairs
Winnipeg MB CA
We lent our van (the 2007 Dodge Caravan) to our son and his family so I could catch up on the maintenance and repair on their van (a 2009 Kia Sedona). The Sedona has 190K km (c. 118K miles) on it.
Lots of overdue maintenance (oil and filter change, transmission drain and fill, coolant drain and fill, brake fluid and PS fluid syringed out, engine AF and cabin AF changed, front stabilizer-bar end links changed, brakes serviced (slider pins cleaned and lubed, brake pad hardware lubed)) and likely more that escapes me.
An Easy Repair
I found the intake-air pipe to have a major crack on the bottom. I wonder how long it's been there, and how the silica counts were on the old oil.
There had been a CEL (two codes - lean condition on each bank) but it didn't come back after I cleared the codes, even though I didn't find the cracked pipe until a week later.
Anyway, it's replaced now.
More Repairs:
Parking Brake
Changed out the R parking-brake cable (seized) and replaced the parking brake shoes and hardware on that side. I had not worked on a drum brake in a long time. This did nothing to make me miss them.
I still need to change out the L cable and change out the shoes and hardware on that side.
AC Delete
The compressor started making a horrible noise about a year ago. Besides them having no AC, I was worried about the compressor seizing and taking out the serpentine belt.
I took the van to a shop to have the refrigerant removed legally. They said it had already leaked out of the failed compressor.
For the interim, I installed an AC delete unit - an SKP product that replaces the compressor. Basically it provides a free-wheeling pulley instead.
The first one from RA was broken. The return process was easy, and the new one was delivered this morning.
The engine sure sounds a lot nicer without the screech and whine of the dying compressor.
To be done:
I plan to change the rear stabilizer- bar bushings, which I suspect are the source of the thumping noises from the back.
If I'm really ambitious:
The engine (Hyundai/Kia Lambda 3.8) has a loud valvetrain tick.
The pundits say that the cam lobes push directly on little cups with a certain shim thickness. The cup then pushes on the valve stem.
The ticking is typically caused by excessive clearance, and the solution is to remove the camshaft and replace the cup with one with the appropriate shim in it.
Sounds scary. I'm running out of time, so perhaps it will go to the pros for this work.
Kudos to you for bringing there van up to par with maintenance and making it a whole lot safer. Hopefully it gives them many more years of service.
Thank you!
Prices on used vehicles here remain very high. With three little ones, two still in car seats, they'll be in minivan land for awhile.
If this has bought them another two years out of the Kia, it's been money well spent.
Thank you!
Is A/C not needed in your climate? No A/C would be a tough sell to most parents.
AC is preferred here - to quote Garrison Keilor, "it seems unfair that the nation's icebox is also its oven".
He was referring to Minnesota, but the Canadian Prairies have a similar climate, with the temperatures unmoderated by nearby oceans.
When I had the AC checked at a trusted shop, they said they were unable to find a low-mileage compressor that day. (In their experience, the Hyundai/Kia compressors usually fail by 150K km here, so they won't install one with > 100K km.)
I considered ordering one from RA, but was unsure of what to get. It seemed like there were various qualifications; I didn't want to get the wrong one. I've now pulled the original compressor, so it will be easier to match.
In the meantime, I was very concerned about the possibility of the original one seizing up and stranding them and possibly destroying the engine.
So the AC delete unit is a stopgap measure to get them through until next summer. AC season is almost over here; there will be a handful of hot days in September, and that will be it until May or June.
Here's the old compressor:
Here's a shot of the AC delete unit's pulley (at bottom centre):
Here's a shot of the AC delete unit from underneath:
