Hello All.
Rob in Vegas here, got a question.
We have been having a HUGE problem with Mazda RX'8 blowing engines in the Vegas heat this summer.
One dealership alone (Magic Mazda) has already replaced over 20 engines this summer.
These are 2004 RX8's with between 10k and 20k miles on them.
The general theory seems to be that the oil coolers on the cars are not robust enough.
The oil is heating up and eventually turning to sludge. The engine temps are getting WAY high and eventually the APEX seals on the engines are "warping"
Causing a lose of compression and then engine failure.
Mazda ONLY recommends 5w-20 for ALL RX8's
No matter what part of the USA you are in.
This was apparently done to satisfy EPA regulations about emissions with the RX8's.
Mazda does NOT endorse ANY syn oils.
My question is this.
What grade and type of oil would you recommend for HIGH temps like we get in vegas. This summer we had a stretch where temps were between 112-118 for about 2-3 weeks straight.
Most people here do A LOT of city driving. Very little long drives, very little freeway.
Some people have reported engine OIL temps in the RX8's hitting 240+ degrees.
Any thoughts would be much appreciated.
Rob in Vegas.
Rob in Vegas.
