I changed the passenger engine mount in my Mazda 3 and after looking at it, it is really a weak design. The oil inside the mount leaked out about two years ago after I hit a pretty deep pot hole. I was putting off this change until now, but I didn't want to push my luck any further.
I just want to share the pics with people owning Mazda 3, as total mount failure can cause some serious collateral damage to the drive train.
Here it is looking normal. Still I couldn't help but wonder why is it so thin at the base
Sorry for the orientation, the base is on the right side of the picture.
And here is the damage revealed. It is plain to see that the very bulky top portion does not bear much weight of the engine. It is really the bottom portion that needs extra material to deal with all that weight being transferred from the top of the engine mount.
Basically the rubber shears off at the joint with the aluminum. Mine was sheared off almost all the way around, except a small portion still holding the mount together. Once the thin, cone shaped, rubber part separates from the aluminum, there is nothing connecting the two and the engine can drop down on the passenger side.
On the positive note, at least the mount was very easy to change.
