Mazda3 2014 Engine Mount & Clutch Shudder
My 2014 Mazda 3 (2.0 stick) has developed some clutch shudder. It's most apparent when cold and goes away when it warms up. It's got about 42000 miles. Also, the passenger side engine mount (#3) is leaking with oil seepage around it. I wouldn't say it's blown, still feels solid, but definitely leaking. Mazda issued a service bulletin (01-012/16) for this #3 engine mount and has a new/revised part (GHY1-39-060 / GHR9-39-060A). Despite the low miles, it's out of warranty on calendar time. It's about a $100 part and labor is free (DIY).
I suspect these problems may be related. I plan to replace the engine mount, since it's leaking and I should replace it anyway to get the revised part. If the clutch shudder goes away, great, I'm done.
Question: what places do you recommend for buying OEM Mazda parts?
Interesting that it's when cold. My '99 Camry, 5mt, does this too. I have no idea whether my clutch is about to go, but I do know it's butter-smooth, after the first two or so starts-from-a-stop of the day.
Here's my take on troubleshooting. Feel free to fact-check:
Clutch shudder (not clutch slip, but being too grabby) is often a problem with the clutch surface or flywheel. Excessive or uneven wear, hot spots, etc. But if this were the case it would shudder all the time, not just for the first cold start.
If the clutch shudders only on the first cold start, the cause must be something that disappears quickly. One likely cause is moisture on the surface caused by condensation, which being water (unlike oil), quickly scrubs off or evaporates. If it were oil contamination it would happen all the time, not just when cold.
A faulty motor mount exacerbates the shudder.
As this is quite a popular car, here's a public service update:
I got the new engine mount for about half the usual price on eBay from "partsbrokersllc" who has 100% feedback with 42,500 transactions. It's a new OEM part. It is the revised version, but I can detect no difference in construction from the original. Whatever Mazda changed isn't externally obvious.
The OEM mount bolts were torqued well above the specifications in the manual. I actually broke a 3/8" socket extension getting them off! After removing it, I clean up the residual fluid that leaked all over the engine so it's clean again. Both mounts, old and new, are more compliant/flexy than I expected, meaning the rubber has quite a bit of play. Installed the new part. Next morning cold start definitely had less clutch shudder. Just a hint, but much less than before. And there is less vibration, at idle you can't even tell whether the engine's running. The slight vibration it used to have is gone. After an hour of driving I loosened the engine mount bolts then re-tightened them.
Overall, while the original engine mount was still serviceable, I give this update a thumbs-up per Mazda's service bulletin. Yet if you're racing (like SCCA) you might want stiffer engine mounts.
Another update: after a second morning, this one much wetter than yesterday, clutch shudder is fully back. So the engine mount didn't fix it. I guess yesterday wasn't wet enough. The work wasn't a complete waste since the old mount was leaking and the part was revised, so I needed to replace it anyway. But too bad it didn't fix the clutch shudder.
However, I've learned it's definitely related to moisture. Only happens when both cold and wet.
I can do cold starts very carefully to avoid the shudder. So I might decide not to fix this.
That said, any ideas why a clutch might shudder only when both cold and wet?
A year later - another update: I started parking in the garage and the clutch shudder is gone. The good news is that this means the clutch surfaces, flywheel, etc. are in good shape. No need for an expensive replacement. The bad news is that I don't know what actually causes it, can only assume it's some combination of cold and wet environments.
Yeah, my focus does this on the first couple starts when its been damp overnight, and actually makes a bit of a moderate howling noise. I find if I do a bit of higher rpm slipping on the first start it goes away.
See if RA sells the OEM part, but I usually find the Mazda part number and do a Google Shooping search on it. There are many dealers that discount from retail and sell online. They will operate under various URLs, but most are dealers. Just see who has the best price and don’t forget to compare shipping. I have used BAM Wholesale, but have bought elsewhere based on price.
My manual transmission Kia Soul does this every first few starts of the day when it’s been damp or humid overnight. It’s annoying and I can’t remember my older cars ever doing it, but a few 1st gear starts later it’s fine. I just take it easy until it stops.
I mentioned it to the dealer and he said it’s most likely condensation. I googled it when I first got the car and saw posts on some Subaru, Hyundai and BMW forums and everyone seemed to say the same thing. Condensation. Maybe clutch disks are made of something different than they were 20 years ago. 🤷‍♂️
Which part? I already replaced the engine mount (which had a TSB issued) and the clutch doesn't seem to need replacing.
Was responding to this:
My 2011 Mazda 6 has had clutch shudder for a long time now. It happens when it’s sat for a while without being driven and it has rained. It usually goes away fairly quick. I wouldn’t worry too much about it. It’s annoying but it’s part of life with a MT car. As you’ve mentioned it’s likely due to moisture/humidity getting into the clutch.
Good to hear I'm not the only one. I've owned other MT cars over the years and none of them have done this, so it was new to me.
My Mazda 3 does this as well. I always assumed the flywheel flash rust sort of like a rotor and the shudder is it getting cleaned off.. I have replaced my clutch and had flywheel resurfaced since I’ve had the car
And the replacement clutch still has the shudder? That’s good to know. Shortly after buying the Soul I considered having the clutch and flywheel replaced because of it…thought maybe the original owner didn’t know how to drive manual and wore the clutch out. Glad I didn’t do that.
It does but its really minor now. 2-3 take offs tops and its normal. I will say the bad throw-out bearing on my car's symptoms were an awful shudder and noise. When I had it apart the flywheel looked like a mirror so its no wonder it was jerky before even prior to throw-out bearing failing completly.
Fast-forward a few years, the car still had this issue. It never got worse, and since it never happened after warming up, I knew it couldn't be anything serious like wear or bent parts. I began to wonder whether the root cause was the engine, rather than the clutch or mounts. After a cold start when you let the clutch out and give it gas, you are loading the engine for the first time when it's cold. If anything with fuel, ignition timing or spark isn't perfect, that's when you'll notice.
Recently I passed through 60k miles and inspected the spark plugs while changing the coolant. Two of them measured > 10 kOhm. The specification is 3.0 - 7.5 kOhm. I cleaned them with a toothbrush & gasoline (as recommended by the manual). Then all 4 measured between 3.9 and 4.2 kOhm, which is in spec. I checked the gaps, all were between 1.07 and 1.12 mm, which is in spec (1.05 to 1.4). I reinstalled the spark plugs in different positions (e.g. rotating them). The clutch shudder when cold is gone!
Apparently, over the years and miles 2 of the plugs had gotten just enough dirt/contamination that their impedance went too high. This means weaker spark. When cold and under load (worst case scenario), the weak spark was insufficient causing misfiring and shudder. The plugs didn't look too bad visually (I've seen much worse), but the multimeter doesn't lie and it's the impedance that matters. If the problem comes back I'll replace them.
