Okay... I have over 230K miles on my Honda Accord and I changed the TOP Passenger side Motor Mount.. Actually I'm on my 2nd.
Now I changed the 2 Automatic Transmission Mounts...
Now here is where Im confused.. I have read that the REAR Mount has OIL in it..
Also I can see that the front mount has a hose running to it.. Now on some sites like AMAZON they say its Vacuum hose
and others they say its Hydraulic Mount..
So again I replaced the 2 AT Trans Mounts and the TOP Passenger Side Top Mount.. ** TORQUE STRUT **
It says this on some sites like AAP
Product Application
2002 Honda Accord V6
Front; Front; Denotes Hydraulic Mount
Rear; Rear; Denotes Hydraulic Mount
I read this on a site
We offer it both ways as the vacuum is only activated under a fail safe low idle condition and very few vehicles actually need it. When the vehicle is at normal idle or above the vacuum does not even come into play. For that reason if your vehicle has a normal idle you can install a mount without the vacuum line and just plug off the tube on the engine side. For your information - it is not a seal of any kind, the vacuum just controls the stiffness of the mount below normal idle.
Then I read how people say you can get with or without the Vacuum.. like above..
However I like it to be Exact OE...
I'm totally confused
Look at AMAZON
So Now Im do not know if the front is Vacuum even though I can clearly see a Hose when i pop my hood and look at the
mount and see a what I think is a vacuum hose connected to the mount..
However the Rear mount I do not see a Hose.. Now 1 person told me that Hydraulic oil is inside the mount... However the
picture clearly shows a Line / hose.. So Im very confused
Anyone else run into this problem..
Any Info would be great.
Thanks
