Those old Ford engines needed all the help they could get.
Thought these had the Mazda MZR which Ford rebranded Duratec? Only exception being the V6.
In Mexico, Central America, South America, the Carribean, Africa and the Middle East, 20W-50 and 25W-60 were until relatively recently or still are the most common grades.
The Duratec 2.0/2.3/2.5 and 2.0T Ecoboost is based on the Mazda L engine, which is part of the MZR family.It would depend on where the engine was built. I don’t know that answer. Mexico and Flat Rock would have been closer obviously.
What is best for engine life, is not 0W-20, in most circumstances. Oil makers simply acknowledge that these oils are for fuel economy, while providing adequate protection. Most of us won't drive, and don't expect to get, 900,000 miles in an inexpensive vehicle.So you are saying OEM's specify oils based on what is available in the local market, and not what is best for the engine???
Film thickness (not film strength) ... ie, when MOFT goes to zero. This is why MOFT headroom matters.Bearings last just fine with almost any viscosity, right up until the load exceeds the film strength.
With many misconceptions spread around.Most people think AE Hass' oil 101 is fact.
Wonder how far that 439k Subaru would have made it on 10w40 before ventilating the block…What is best for engine life, is not 0W-20, in most circumstances. Oil makers simply acknowledge that these oils are for fuel economy, while providing adequate protection. Most of us won't drive, and don't expect to get, 900,000 miles in an inexpensive vehicle.
900K miles.Wonder how far that 439k Subaru would have made it on 10w40 before ventilating the block…![]()
Exactly, sorry for being casual with my words. It is an exceedingly complex subject, and the testing results are somewhat difficult for the average guy to accumulate, then draw conclusions. That's what makes BITOG so incredible. I was never an oil test engineer, only a removal and reinstallation tech that was involved in gas turbine (aviation) oil (Mobil 254) and grease testing and also 2 stroke race outboard engine testing (removed and installed powerheads and drove boats) and a tech involved in camshaft development for turbocharged 2.3L engines. My curiosity drove me to a career in aviation, with a background in engineering, flight and maintenance. Second career in turbocharged race cars and engine building.Film thickness (not film strength) ... ie, when MOFT goes to zero. This is why MOFT headroom matters.
This is a good point. As we have seen here, some engines can't be "fixed" with the choice of oil or oil viscosity. Some engines are just not designed or manufactured well, and use inferior materials or lack good metallurgy to last as long as engines that are designed and made well.n the end, bearing life is just one aspect of engine life. Today's engines may or may not contain parts designed for a very long service life with the manufacturers oil choice. Low tension piston rings may not wear much, but the oil consumption that results from that miniscule wear is still problematic to the car's owner and may in fact result in a teardown.
