Originally Posted by Shannow
It's not the water, unless StevieC somehow managed to get water into his first tank of E0, enough to overcome the residual ethanol...but then it should be in the bottom of the tank, not in the injectors....that's where the water goes when there's no co-solvent.
Well, any ethanol / water combination does settle to the bottom.... of a vehicle that isn't moving around. But it mixes up a little with the other fuel when the vehicle is driven, and even if it didn't. fuel pickup tube grabs fuel from the bottom of the tank. So it is going to get moved thru the fuel system one way or another.
