My 3.3L has 2 or 3 minor oil leaks…(not a rear main seal), would my engine leak even more with the new Mobil 1 High Mileage oil, or would Maxlife be better? Mobil's web site says their HM syn is for engines were conventional was previously used...
Quote:
Maxlife is less expensive.....I really like the stuff.
Quote:
I was discussing Maxlife "syn blend" vs HM Mobil full syn.
I called Mobil, and they advised me against using HM syn in my car and stick with a blend at the very least...So I'm staying with Valvoline MaxLife. Also...I asked them if the seal conditioner swells the seals and they told me that it condtions and swells them. There has been discussion in this forum regarding this issue, so it is ver likely that Valvoline MaxLife actually swells the seals as well as any other HM products. Tallpaul...your thought?
Quote:
If I put in an oil that started leaks and there was no strong reason why I need that oil, I'd not use it again. If you can keep the leak from making a mess, run it a normal length OCI, but if not, dumping it early to spare a mess may be worth it.
