Maxlife dex/merc price in USA
Halifax, Nova Scotia, Canada
Generally everything is much more up here and after looking for fluid for my Transmission today it made me curious of prices down south.
The only thing I have found so far that fits the bill locally is Maxlife or Castrol Import but nobody has Castrol in 4litre jugs locally. Have seen as low as $6 at Walmart and as high as $9/l for Castrol import atf at Parts source.
Maxlife dex/merc at Walmart was $25/5 litre Jug which is probably what I will go with but curious what these 2 go for down south.
2012 Nissan frontier 4.0L
Maxlife ranges from $17-23 a gallon, depending on where you get it. Not all Wal-Mart stores carry it, but those that do have it for $17. Most national parts chains carry it at the higher end of that range.
The American price for Maxlife ATF is $17 for a gallon, $5 for a quart.
At least down here, ATF is sold by the gallon as opposed to the 5qt jugs used for motor oil.
My jug was $16 and change, used a $5 coupon, $11 and change.
There is a $12 off two jugs Maxlife if you need a lot.
Red gallon is Dexron VI, blue gallon is Dexron III at Maul-Mart...
My Saturn specs Dex III, and is not compatible with VI
AAP and PB are about $27 by me (call it 40 miles north of NYC) but Wally just started shelving it my me and it is $5 a quart or 16.99 for 4qt jug. I've stocked up a bit! I use it in all the vehicles in my sig including the Armada and 150 transfer case.
Without MaxLife ATF I'd prob swing t M1.
For jugs...AAP has it for $22 around here and Autozone has it for $16. Both have it for about $7 a qt. Walmart does not carry it. I forget what Napa/O'reilly's sells it for.
I bought two gallons at AZ locally for $13.50 each in February.
Not sure why there was this surprise markdown, since it was neither a clearance nor a sale price.
Regular price is around $17.50 from AZ, Walmart or Meijer.
$25.00/5l jug sounds pretty reasonable and is not too much above US pricing.
Originally Posted By: MobilinHyundia
Castrol Import ATF is available at Partsource for $32 Canadian here in Toronto Ontario.
Yeah just found some at the canadain tire for $30. gallon jugs(3.78l) 5 litre of Maxlife for $25 at Walmart is the best I have found so far.
Seems most prices are comparable to those in the US with Castrol being slightly more more.
Thanks guys.
