Maxima Mercon V
ga
Mercon V is compatible with Nissan Matic. Was gonna use Mercon V to drain/fill the Maxima AT thru the drainbolt and do multiple Mercon V ATF changes over a few months. I have some Dexron II that I won't be needing. Any harm in running some of the Dexron II in the first drain/fill if it will only be in for a few months?
scrier
ga
The manual just said Nissan Matic - its a 95 Maxima. The WalMart Supertech says Mercon V is compatible with Nissan Matic J
RI
It'll be D or K for a Maxima. Its old enough that I'm guessing D which would be Dexron. Mercon-V is a good choice as is any universal or multivehicle ATF.
