Mixing ATF's
North Texas
I'm certain this has been covered but for the life of me i cant seem to find reliable information...
Can Dexron/Mercon III and Mercon V be mixed in a transmission that is spec'd for Mercon and has been now approved for Mercon V?
Car has 100% DexronIII/Mercon in it now and thinking of doing a drain and fill at some point in the future using Mercon V or a multi-use ATF that is MerconV rated.
Yep!
Now that you have clean ATF from a flush, regular drain/refills will keep it clean.
That's my plan, a drain and fill every 10,000 miles or so, but at that rate just using walmart or coastal dexIII/merc may be good enough..?!?
10k or at least once a year is reasaonable. Any ATF is OK.
But why cut corners? Its not like Mazda has a great reputation with their self destructing automatics.
Consider quality name brand fluids. If over 100k miles, use one of the high mileage ATFs.
If it were mine I would ugrade to a synthetic blend. Any of the Mercon-V's or multivehicle ATFs would work great for those 10k intervals.
If store brand is your choice, Walmart and coastal have high mileage and multivehicle ATFs.
I just mixed 2 qts castrol dex 3 multi vehicle atf with 1.5 qt mobil 1 dex 3 atf and a full bottle of lubegard red for my 96 sunfire. I used castrol dex 3 multi vehicle because they don't seem to sell only dex 3 anymore. what do I know, my 96 sunfire 3 speed auto hasn't been serviced in 50k miles/5 years. no drain plug, have to drop the pan/filter to change fluid. The manual says change 50k severe use. I use it for normal driving, it doesn't have to be changed. I just go by the severe rec's for the auto transmission
I'll be doing drain and fills with Amsoil ATF on the Honda and F150 from now on.
Honda's transmission rebuilt at 109k and will drain/fill at 114k and 120k.
Unfortunatly you are so right.
It now has Shell DexIII/Mercon. According to the Shell spec sheets, the Shell, Pennzoil, and Quakerstate ATF's all look identical in the DexIII/Mercon formulation.
I'll likely stick with Pennzoil Dex/Mercon or upgrade to Pennzoil Multi ATF blend that is Mercon V rated.
For some unknown reason i'm on a SOPUS kick lately that's been hard to shake
My only recommendation to Pennzoil would be to make your regular ATF bottles a color other than yellow. I came close to putting 5w30 in my power steering the other day!
