Massey Ferguson gc1723e front axle fluid/oil
Manual calls for permatran 821 for front axle as well as hydraulic system.
Would it be better to use gear oil in front axle? Or is it possibly because of maybe yellow metals in there? GL4 instead of GL5 maybe?
Thanks for any information
It's been discussed before so there's good info here. Doesn't seem to be anything that special really.
Gl4 75/80w-90 is about the same viscosity as a 40 grade oil and yellow metal safe which the front diff could have as I don't know. Don't imagine though. Though plenty of diffs, hydraulic systems, and transmissions have called for plain motor oil in the past.
Seems to be a 15w-40 or 10w-30 in viscosity.
https://parts.agcocorp.com/ca/en/p/permatran-821xl-plus-extended-life-2-5-gallon/79035449
