Originally Posted By: skyship
Originally Posted By: urdrwho
I think that was it, I fell for the label talking about adding it during oil changes.
"Marvel recommends replacing between 10 and 25 percent of your motor oil with MMO. "
I didn't add it at every change but I did use it more often than not.
In my one car directly after an oil change with MMO added, a terrible leak started at the rear of the head. There is a plate at the rear of the head that is
impossible to reach, impossible to replace the sealing gasket. It was dripping onto the exhaust and smelled. All that i could attempt is to take RTV and smear around the plate as best I could. I could not reach all of the plate and to this day, I still get drips.
The last time I had an experience with oil leaks after an oil change was 15 years. At the time the car I bought was high mileage and synth oil was the new rage. I tried it only to witness oil seeping from all kind of places. I think the same can happen with MMO.
Using solvent or thin oil cleaner additives can be one bad idea in any modern engine and in particular ones with turbos. It says in the worlds most common but least read book (The owners handbook) do not use oil additives and they say that for very sound reasons.
With older engines you might have an internal varnish layer coating part of the shaft, oil seal or gasket and if it gets dissolved then you can get an oil leak.
If you think you have a minor sludge case (very rare if you use a good oil and OCI), use an oil additive designed for idle use only just before the oil change
and then consider using an oil with more detergent like a major brand synthetic or if you have oil leaks an HM oil with a shorter initial OCI.
Liqui Moly and Amsoil both make good idle only flush additives, that are safe for any engine.
Aren't these products solvents? Doesn't the owners manual state not to add anything to oil?
How exactly will these products clean differently than mmo? If there was a gasket failure that mmo made leak,how will these solvent flushes prevent that from happening?
So your saying it's ok to use an idle type solvent flush but not ok to use a leave in type of flush. If they both clean deposits how will one not cause a leak that the other will?
Just trying to figure this one out,since both are solvents,just the routine is different.
