Quote:
My friend just bought a 97 Mustang Cobra and he wants to put in new transmission fluid for his 5 speed manual.
Does the '97 Cobra have the same Borg-Warner T45 5-speed as the '97 GT?
I've got a '97 GT with a Borg-Warner T45 and it seems to do okay with RedLine D4 ATF. Went to it with 8k miles on the clock, now have nearly 40k on it. It gets driven spiritedly. Okay, I'll be honest, my wife likes to race teenage boys with weed-wacker exhausts and then call them names that insult their manliness when she wins.
With both of us in similar cars, she'd probably beat me! So, the car gets flogged, often. It's a blast to drive.
To be fair, I will note that when I had the stock fill ATF in there, I have some issues with the 5th gear (yes, 5th gear!) synchro not working right, causing a bad grind coming into 5th. (It was my father's car and out of warranty when I inherited it.) The D4ATF did nothing to help the 5th gear grind, so I just attributed it to the Borg-Warner T45 being a real piece of junk. Interestingly, if I recall correctly, Ford dropped Borg-Warner due to the poor quality and started exclusively using Tremec T45's sometime in/around 1998/1999?
Now here's where it gets odd - in the past year, the 5th gear grind has gone away. Maybe the D4 ATF has sheared down? I don't know.
I wouldn't hesitate to try the Amsoil or the RedLine D4 ATF. When I do the transmission oil change on mine in the spring, I'll use the Amsoil syn ATF.
later,
b
