Neutral, always. Agree, it's like second nature.
Did you read that through ? They word it that use of the handbrake is very subjective and by no means a requirement or mandatory. They say that when you come to a stop "and if it looks like you will remain stationary for a while", use the handbrake. How long is "a while" ?UK driving schools teach their students that way as that's how it's road tested apparently.
I even use neutral in my automatic vehicles when I am at a long lite or drive thru lane. Front pump runs then.
Not doubting you but I'd like to see the wording of this. If it is actually a law, it's another unenforceable one.My state requires you to stay in gear when the car is moving. I found this out on my driving test when I was coasting up to a stop light.
I found it.Not doubting you but I'd like to see the wording of this. If it is actually a law, it's another unenforceable one.
Laws like this date back to the day when cars had barely adequate drum brakes and if you rode the brakes down a long hill they would be faded to nothing when you got to the bottom. Obviously this can still happen, but it was way worse when your 5000# Packard was boiling it's fluid and had hot greasy banana peel brake shoes after going down a pass.I found it.
(625 ILCS 5/11-1410) (from Ch. 95 1/2, par. 11-1410)
Sec. 11-1410. Coasting prohibited.
(a) The driver of any motor vehicle when traveling upon a down grade shall not coast with the gears or transmission of such vehicle in neutral.
Not exactly what I was told. Maybe I was on a downslope at the time? Surprising they are worried about grade in a mostly flat state.
Early 90s I lived in Birmingham, England, and yes my roommates girlfriend used to pull up the handbrake while at a stop sign.That's what I've always thought but I guess some people do it for safety as opposed to putting it in neutral and pulling the handbrake (I guess that's how they're taught in Europe?).
Depends if you want to wear out the thrust bearings on the crank or the throw out bearing first.Do you keep it in gear with the clutch depressed in order to have a quicker take off, or do you put it into neutral to save the throw out bearing?
Curious to hear opinions and why. I almost always put in into neutral if I'm going to be sitting for more than 5 seconds because why waste the TOB?
A new clutch is always cheaper than a new crank.What's cheaper to replace?
Let it rest in neutral.So you're saying just hold it in?
