Originally Posted By: EagleFTE
I don't think anyone is suggesting that sir1900 does nothing to correct being a quart low after 5000 miles. The one thing that he needs to do is top off or change the oil. But if he is spending $25 on a used oil analysis he has to consider what he wants to learn from that used oil analysis. He could take a sample prior to top off and see what the situation is after 5000 miles. He could take a sample and do an oil change, same used oil analysis. Or he could top off and wait another xxxx miles and do the used oil analysis. The third option will pump up the TBN for a while and have some other positive impacts. So it all boils down to what conclusions he wants to draw from the used oil analysis. The one thing he can't do is continue driving a Qt. low.
As soon as I discovered I was low on oil, I added a quart without hesitation. I am aware that running low on oil isn't very wise. The makeup oil came off of leftover oil from two previous changes. The stock, date and time of production in the makeup oil is the same as that of what is already in the engine.
The main goal I wish to achieve with a used oil analysis this time around is to see if the wear numbers have gone down at all. My previous two used oil analysis showed high Iron and Lead. Both those used oil analysis were using Mobil 1 5w20. This time around, I switched to PP 5/20 in the hopes of achieving better results.
I will probably end up doing a TBN simply because I have done so for the other 2 other used oil analysis. However, unless the oil consumption is getting worse, I will likely take it to 0% on the OLM before I change it out.
