Anyone know why one product is better than the other ?
The Flat Roof membrane was installed about 2.5 years ago and apart from some discoloration (weather, hurricanes, algae), is not leaking and can be washed. Normal service life for this rubberized membrane is around 10 years with maintenance.
Flat roof is attached on 2 sides to a structural gutter (ie. "supergutter") where water runoff goes over edge into a very heavy anodized aluminum wide/deep gutter. You can literally walk inside this gutter due to it's material strength.
When the membrane is installed over pressure treated plywood, it is torch heated into the wood and has small grey sandy material on the surface side. Over time, this sandy material washes off and the surface will last longer if an elastomeric material is applied. Several companies make these, locally Acrylux is known for their roofing elastomer products.
Am considering these, feel free to comment or suggest a completely different product.
Home Depot, Lowes and Amazon all sell these
https://www.amazon.com/COMPANY-HE687406-Enviro-White-Premium-Coating/dp/B005HWWFHM/
https://www.amazon.com/Henry-HE887HS073-TropiCool5GAL-Tropicool-gallon/dp/B00OMRF05W
