Magnetic sockets?
JHZR2
Staff member
New Jersey
A few times recently I’ve needed to get a screw or bolt with a hex head, into a near-blind hole, in a vertical position.
A magnetic socket would have been nice. Maybe a socket with a small magnet on it or in it.
Does anyone do this? Any best practices?
Think 8-10 mm heads.
  • Like
Reactions: JC1
I have the sunnex 1/4” set and they are my most used sockets(mostly work on motorcycles). Goes down to 6 or 5mm, can’t remember.
Highly recommend.
For 3/8 drive Astro makes a good set
Magnetic sockets are great tools for the job you describe. There is a "redneck trick" if you want bolts to stick to normal sockets though, wrap a thin layer of tape around bolts head. I use PTFE sealing tape around the bolts head and the bolt will stick quite well to the socket.
There's been a few times where I needed a magnetic socket, but as time goes on, I forgot why. If I ran into the issue on a regular basis, I'd get only the sizes needed I and they would probably be from Snap-on. I'm getting too old to be taking chances on iffy tools.
I don’t think for the small 8mm head screws that were causing me issues, that this would work.
I have this set but with matco stamped on it.
I’ve never used magnetic tipped sockets just the ko-ken nut grips. They work incredibly well.
If you’re tired of dropping nuts and bolts ko-ken nut grips are the answer.
I don't want any magnetic sockets. I drop sockets too often when I work on cars and they are hard enough to find without them sticking to something.
I too just have magnetic nut setters. It's a compromise but a couple times per year can be useful. I tend to hoard the cheap ones as I almost consider them consumables. They seem to vanish or the epoxied magnets fall out and they're not worth trying to re-adhere.
Both the problems above could be cured by 1) being more conscientious about tool placement/storage and 2) just buy quality....but for some reason I like cheap ones I can use and abuse.
Finally, if you really wanna git jiggy wit it, GW offers magnetic hex keys.
I show both products here:
https://bobistheoilguy.com/forums/threads/new-tool-thread.328515/page-119#post-6375462
I use a small piece of masking tape over the socket to hold bolts and nuts.
