Hey George, Purolator is fine, just make sure that its gasket is tight and it's sealing well. Earlier I was thinking that maybe you were using one of those reusable filters which have to be moistened with engine oil. Those can sometimes contaminate a MAF.
Take another peek inside the air cleaner housing. Look for any oil stains, puddles, or residue inside the filter housing, or on the filter. This might indicate a problem with the PCV system which is allowing crankcase products to enter upstream of the MAF.
Also check the hoses which connect to the PCV valve. It's possible for the hoses which connect to it to be obstructed, or cracked. Even if the PCV valve is good, problems with those hoses could cause oil mist and crankcase gasses to flow backwards through the system. Check for vacuum leaks in general.
Another possibility is that the MAF is actually OK, and your problem is the wiring harness or the connector. Maybe the contacts on the connector are oxidized or splayed. A bad crimp on one of the pins could cause an intermittent. A burned or chafed wire somewhere in the harness is another item to consider. Don't overlook those possibilities.
Who knows, maybe everything is OK, and you just had a run of bad luck with the replacement parts. It happens.
