Originally Posted By: d00df00d
There are plenty of plausible explanations for the slightly "elevated" wear metal levels indicated on UOAs with Mobil 1. This topic has been beaten to death, but here's a quick summary:
- Certain oil formulations could conceivably throw bigger numbers on UOAs when there is actually LESS wear.
- The method of spectroscopy used by most UOAs doesn't always give a reliable indication of wear; you could easily have low numbers with big wear, or big numbers with low wear.
- Sometimes, switching oil brands or types can cause wear metals levels to spike briefly before settling out.
- The numbers on a UOA report don't tell you WHERE in the engine the metal is coming from; if Oil A gives you 15 ppm of iron from all over the engine, and Oil B gives you 10 ppm but it's all coming from the cams, Oil A is probably a better choice.
- Something about the car may have changed around the time that the owner switched to Mobil 1.
There's no certainty to any of these, of course. It's also possible that Mobil 1 really is yielding more wear than other brands. The point here is that no one can tell because no one has ruled out those other possible explanations.
What we do know is that Mobil 1 products have a great deal of very powerful endorsements from a broad range of powertrain builders. That has to be worth something.
I don't use Mobil 1, either, and probably never will (unless I have to use it for warranty reasons or something). However, I think it's safe to say that saying Mobil 1 is bad or worse than other oils just because of some $20 UOA reports is bogus.
Good info, we can't forget how many mistakes they make with these reports either. LOL
