What do you think of this grease guys ? Polyurea Thickener
Lucas X-TRA HEAVY DUTY NLGI GC-LB Data
ASTM Result GC LB
Penetration, Worked 60 D 217 280 220-340 220-340
Dropping Point, °C D 2265 260 220 minimum 150 minimum
Oil Separation, Mass % D 1742 0.3 6 maximum 10 maximum
Rust Protection, Rating D 1743 Pass Pass Pass
4 Ball Wear, scar diameter D 2266 0.5 0.9 maximum 0.6 maximum
4 Ball EP Performance: LWI D 2596 50 30 minimum 30 minimum
4 Ball Weld Point, Kgf D 2596 400 200 minimum 200 minimum
Fretting Protection, mass loss D 4170 6.1 X 10 maximum
Elastomer SAE AMS 3217/3B compatibility, volume change, % D 4289 27 X 0 to 40
Water Resistance at 80°C, % D 4289 -12 X (-15) to 0
Water Resistance at 80°C, % D 4289 16 (-5) to (+30) X
Water Resistance at 80°C, % D 4289 -4 (-15) to (+2) X
Water Resistance at 80°C, % D 4693 6.6 15.5 maximum 15.5 maximum
Water Resistance at 80°C, % D 1264 2 15 maximum X
High Temperature Life, hours D 3527 120 80 minimum X
Leakage, g. loss D 4290 5 10 maximum X
ASTM Result GC LB
