My 2004 Jetta with 150K miles consumes about a quart of oil every 1k miles. Since I only drive 7K a year and consume so much oil, I do a once a year OCI, using 10W-40 in April , then start topping up with 5w-30 heading into winter. No gelling, and worked great last year.
The last change, however - due to lifter tick and pressure loss, my mechanic recommended LOS, which I did use (and did help).
This year with the LOS, it still seems pretty thick and suspect the LOS isn't being consumed as much as the lighter weight oils, and am concerned with gelling.
Is there any way I can thin what's in the crankcase down a little bit heading in to winter?
