Wondering if anyone has tried this out. After getting turned on to the Lubro-Moly MoS2 anti-friction treatment, I stumbled upon this stuff from the same outfit. Product claims:
* Reduces oil consumption via the piston rings and valve guides
* Prevents blue, smoky exhaust fumes
* Prevents leaks due to leaks at elastomeric seals
* Regenerates engine seals made of plastic and rubber
* Prevents pollution of the environment due to oil dripping from the engine
The first claim is a possible solution for my own oil consumption, as I am burning it from sticky rings. That being said, I have also seen consumption drop claims from MoS2. I'm going to go with just the MoS2 for this OC to see if that helps first, and because my consumption is falling off as outside temps are beginning to drop and I will burn less over the winter.
Where I plan to dose with MoS2 every other OC, I might try this stuff between the MoS2 OCs (starting with my spring OC when consumption starts to rise again). Anyone have any experience with it?
-Spyder
-Spyder
