IIRC Tornado-red? Not sure on the SN spelling posted a UOA with Lubro-moly in the sump. It was quite a while ago, maybe he'll check in.
The Oil color was attributed to the Moly, demar. That may have been the poster that -also- observed rust-colored Oil drain? These WAS at least one other poster that mentioned "Rust colored Oil" upon drain, first drain, after 1 can of Moly app, as I did. Perhaps MMO mixed in with it? The engine I have may be fine, coolant contamination was a possibility, technically still may be, however other things need to be looked at/replaced before HG gets blamed. HG may even be perfectly fine. There are conflicting messages all over the place.
Maybe the Moly displaced some rust. There are those that say Piston/Cylinder walls can rust. I .. find that hard to believe?
Since when did Moly "Clean" anything? r clint also doubts its abllity to plate metals and internal surfaces, something about "There is only x amount fo surface area for it to plate, so excess Moly causes things to turn to muck." That was a PRIME suspect of the neat caramel "Swirl" my Oil had, when sitting in the drain pan.. boy, having a camera would have been ideal.
FWIW, putting my hand in the Oil to see if water was sitting on the oil, as water and oil do not mix, did not yield any water. Leading me to believe more that it was weird Moly effect, not coolant. I also know Moly will, on theory, do nothing for the HG. However, if it plates things.........................
