Originally Posted By: Donald
Originally Posted By: Warstud
*DO NOT LUBE THE TRACK* You can lube the rollers as long as there not sealed. The chain is supposed to be factory coated and usually doesn't require lube.
The LiftMaster website says every 3-4 years, wipe off the track and reapply a small amount of white lithium grease.
Are you sure it's the track and not the rail? The track is just a guide for the rollers to ride in. And the rail is part of the door opener which the trolley rides along and only needs to be lubed on the top.
