I noticed that the chain on my garage door opener had started to sag..it was hanging about an inch below the middle of the T-shaped track with the door closed. It also seemed like the garage door wasn't going down smoothly. (The door goes up and down fine when I pull the red handle and close/open it manually).
So I adjusted it (at the threaded piece the chain attaches to with the two nuts on it) until it hangs about 1/4" above the T-shaped track with the door closed.
Does that sound about right, or have I overtightened it, or could I tighten it some more?
The door closes more smoothly now--it doesn't seem like it's hanging up a bit like it was before.
