Thanks for the responses. I've had bad luck lately with seized and rotted hardware under that car. First it was a $30 gas tank heat shield that required the dealer to remove and install (hardware, tools I didn't have) Then last week the alignment shop gave up on me after an hour of torches, spays, and swearing.
Its the salt up here. Makes nuts seize, bolts so brittle they disintegrate. Why I ask, concerned about lugs becoming brittle from corrosion and snapping.
Mentioned Kroil because its fantastic for cleaning corroded parts, many tests show good for protecting metal against corrosion. But the fact that it "loosens frozen metal parts" is kind of scary, may be something bad on a lug. Not even a Kroil moistened rag? Bummer cause I'm out of anti-seize and determined to do this right now. That has me a little nervous too after the responses.
