Lewisville, Texas. 1995 Ford Explorer got stuck in mud and water and set for 5 days The vehicle got filled with water & sand in the engine block and after being pulled out, engine would not turn over. Drained fuel tank and replaced with fresh fuel & Fuel Power (1 oz per gallon) Drained engine oil and Filter, put fresh oil and 10 oz of Lube Control into engine block. Took plugs out, put Lube-Control into each cylinder after removing the water, then let the engine set with LC for 12 hours. Then we started engine and let run for 25 minutes.
Next we stopped engine, drained engine oil & filter and replaced with fresh oil and Lube Control...we turned Crank Shaft 180 degrees then put another dose of LC into Cylinders again. Finally, we started the engine and it has been running well ever since! All water and rust removed by emmersion in Lube Control.
Owner of vehicle Jeff Creed (972) 436-7725
