lspi with vavoline conventional?
Has nothing to do about being conventional or synthetic at this point in the game. All about the overall additive composition.
Originally Posted by ernied
while surfing the web I came across an article saynig Valvoline everyday protection helps prevent lspi.
is this possible with a conventional oil?
Do you have a link or source to that article?
I have several quarts of Super Tech SAE HD30 conventional.
It's SN Plus and makes specific mention of LSPI mitigation on the back label.
Interesting the HTHS is higher for the 5w30 than the 5W-20. Must not shear-stretch in the journal bearings? Since OCI's are shorter for GDI engines, I'd think about going with the 5w30.
Even if 5w30 does permanently shear in the power cylinder / valve train HTFS areas, the resultant sheared junk gets drained with the OCI. Worst case you end up with a 5W-20 by a 5,000 mile OCI.
If it's API SN-Plus or SP then it's developed to help prevent LSPI events. It's mostly implemented with a balanced Ca / Mg detergent package and limited (if any) Na detergents. It's mostly independent of the base oil.
That is Interesting!
Though quite believable - -
HD30 is an excellent oil for many applications that people wouldn't think to use it in.
There are a few 5w40s now that are SN Plus also.
IRC a "conventional" oil is better at LSPI prevention over PAO.
