LSPI a boutique word for detonation?
Texas, United states
To me, LSPI just means detonation under load at lower rpm. Especially since manufacturers make a lot of vehicles stay in the lowest possible rpm range while cruising. I've build probably ten high performance small blocks including the 434 sbc in my 72 camaro rsZ/28. We had detonation then on pump gas if you ran too much timing. I ran a msd digital 6 ignition with a locked timing at 28⁰ with a 15⁰ start retard and never had any issues. The only thing I ever had to do was switch plugs when running nitrous. So did manufacturers just "fancy up" the word detonation to LSPI?
Its a case of they are similar but different. Detonation refers to abnormal combustion caused by overly advanced spark or fuel octane below what is required for engine compression/timing. Retarding spark timing and increasing fuel octane rating are the cure. LSPI is more like engine dieseling back in carb days when the mixture explodes without a spark occuring. Timing has no direct effect on LSPI but increasing octane helps decrease the problem.
It's different. The idea is small displacement motors running a ton of boost at low rpm. Like a 2.0 liter motor making 300hp running 25psi of boost in high gear at 2000rpm. I think it's more of a design flaw
  • Like
Reactions: fen
the difference is, lspi isn't cured by pulling timing, and might even get worse. You're giving the oil and fuel mixture more time to evaporate and become combustible. And the oil contains catalysts for oxidation (calcium and sodium) in larger quantity than anti-oxidants like zddp and organic moly compounds.
The claim is cold thick oil is harder for the piston rings to scrape compared to a thinner oil. The oil that doesn't get scraped normally burns off without issue but can cause LSPI.
those claims need to be quantified. Every oil is thick when cold, so what are we talking about? 20 cSt, 1,000 cSt or 60,000 cSt?
even so, there has to be boost involved, and likely lugging. I run my engines at a light load until they get warm, and the tcu luckily favours a downshift over boosting so I'm not concerned.
Remember, these are boosted, high compression, direct injected engines, often with low tension piston rings. So while the old rules still apply, there is a new twist here, as the cylinder pressures are rather high.
Bottom line LSPI is associated with excessive cylinder pressures. 1400-2200PSI is common during modest LSPI events and 3000PSI+ before destruction.
Calcium in the oil has been a contributing factor.
By way of comparison, a 427 Chevy tuned to make 550HP might reach a peak cylinder pressure of 1100PSI at peak torque. About 3x lower than a destructive LSPI event.
That oil stops being cold the moment it touches those 450°F cylinder walls and top rings. The oil in the sump may still be 20°F but the oil around the rings gets hot very quickly.
If there is an increase in LSPI when the engine is cold, I'd think it's more related to engine warmup programming. You shouldn't be WOT and full boost at 1500 rpm on a cold engine anyway, regardless if GDI or not.
Engineer here.
Broadly speaking, there's 2 combustion regimes:
Deflagration - Normally Occurring combustion of fuel/air mixture where the flamefront travels subsonically. Pressure delta is typically small and is assumed zero for simple analyses.
Detonation - Flamefront travels @ supersonic speed and pressure rises sharply, and can/is harmful to the piston & cylinder.
This tells me that LSPI is detonation ignoring the ΔP from boost.
  • Like
Reactions: fen
I recall reading some post that it's CAFE fault. Lug it baby!
Since in Europe they didn't have as much problem with the small displacement Turbo DI engines. And over there, the ECU / Engine / Trans are programmed not to lug as much for a little mpg gain.
Conclusion:
No replacement for displacement & back to manual transmission! No?
Kinda late to the show, but since I still tune carburetors (Webers and QuadraJets I started on lol) and distributors as well as ECUs, and I remember my dad teaching me back in the 80s that knock (detonation sounds like rocks in a can when we would go tuning) so im commenting.
A Detonation event is an even more related to like you said, timing, or also low octane, and hot spots like burs or sharp edges in combustion chamber. LSPI is inherently a Direct Injection and mostly turbo engine occurrence that have a quick tip in or high load event (now days transmission tunes from factory tend to keep them in higher gears to save fuel but I find its hurts MPG personally) but under these conditions and its caused by a mixture of fuel and oil forming in the cylinder like a low octane drop of fuel that spontaneously ignites, and is loud and catastrophic in severe cases, blowing out the ring land of piston most times.
One occurs after the spark (det/knock) and one before (LSPI). More cylinder pressure is created with LSPI vs. det/knock.
