LSJR blends up a custom oil in the lab
Formulating lubricants is a methodology. Briefly, the process is to establish goals (technical, marketing, & financial targets); define tests that confirm goals and support claims; identify potential ingredient types that affect tests (base oils and additives); obtain samples of identified ingredients based on supplier recommendations; create testing matrices; conduct tests and evaluate results against goal requirements; repeat as necessary.
I designed esters and formulated high performance lubricants such as jet engine oils (including the one most used by the US Military for the last 25 years) and various successful synthetic industrial and automotive oils, and have four patents, all with a high school degree and no certifications. Yes I had access to a good lubricants laboratory and quality chemists for consultation as needed, but one can initiate, design, direct, and manage the process without a formal higher education.
The formulation process is more logic than knowledge. You gain knowledge from experience as you go.
100% truth right here
From XOM:
"About 500 blends a month are created at the center. Each blend consists of 15 to 20 different components on average, and by volume breaks down as 75-85 percent base stocks and 15-25 percent wear additives and friction modifiers. Real-world testing begins in the motor shop, where blends are run in cradled engines to obtain high-speed, high-load and high-temperature performance numbers. After testing, engines are disassembled and digital microscopes are used to inspect part surfaces for wear.
In another area of the center, vehicles of every make and model are strapped to dynamometers to test oil blends, sometimes against competitive brands. Cycles can be custom-programmed to generate data for high speeds, stop-and-go traffic, long durations, or any combination of driving conditions."
This is news to me. My car (Volvo XC90) uses a cartridge, which brands should I look for over Wix?
Any of the PG made ones like Carquest Premium, NAPA Gold, Microgard Select, Premium Guard
Although if you have a cartridge filter then you have more options because something like the Fram Endurance is still good in cartridge form because it doesn’t involve the canister and the ruffled leaf springs
If I had Elon Musk money I'd have a lab built that can run every engine test on the planet. I'd source only the best components, hire a top-notch chemist and make sure the oil exceeds every test by a substantial margin. I'd then share that data with customers and publish it. My PDS would have all engine Sequence test data - IVA, IIIH etc. You would know what the score was on every test - TEOST etc. There would be total transparency.
I wouldn't feel comfortable just running basic tests and used oil analysis.
From XOM:
To play the skeptic... how much of that testing involves finding ways to meet the same standard at a lower production cost?
If it’s a new (2016+) one - just get the genuine Volvo for $13 from FCPEuro.
If it’s older, the Mahle from FCPEuro is about $6.
It kind of seems like the work is mostly done for the blender (I'm guessing). I assume the add pack supplier has some general guidlines to follow.
All of the really deep, technical R&D work is done way before it gets to the blender. The blender is likely just putting the pieces together.
I'm genuinely curious though how they go about it. Prior to Amsoil getting their own lab they would just run your basic bench tests as proof of performance. They also would send things out to SWRI.
RL now has P66 facilities, Amsoil has their own lab, Mobil as well. Valvoline can run every ASTM Sequence engine test in-house.
Everyone has certain in house testing - but places like this take it to another level:
https://www.bing.com/search?q=south...s=n&sk=&cvid=EA6E0F478F4848D98B50082D793BF8E6
