Originally Posted By: gregoron
From this quote in a Jalopnik article, it seems like there is a simple fix to this Dieselgate issue:
“It could be something very small,” said Carder, who’s the interim director of West Virginia University’s Center for Alternative Fuels, Engines and Emissions in Morgantown, about 75 miles south of Pittsburgh in the Appalachian foothills.
“It can simply be a change in the fuel injection strategy. What might be realized is a penalty in fuel economy in order to get these systems more active, to lower the emissions levels.”
Source:
http://jalopnik.com/researcher-who-uncovered-vws-diesel-cheating-says-fix-s-1732537775
My question for those familiar with diesel combustion, would adding an EGR lower NOx as they do with GDI engines? Gasoline direct injection engines also deal with direct injection and NOx emissions. High levels of NOx come up when GDI's run ultra lean (i.e. stratified charge mode) and the compression ratio is high. This happens during light-load or acceleration running conditions, or constant low speeds. Fuel is actually injected just before ignition and not during the intake stroke.
For diesel engines, couldn't the EGR recirculate more of the NOx back to the combustion chamber?
Egr is only effective at low loads, so goot enough to get you through the test cycle, but not on the open road.
Oh wait....
It's not the NOx that's redirected, the aim is to lower the Air-Fuel ratio so there's less excess oxygen and NOx doesn't form in such abundance.
Quite a few engines here in europe supposedly meet euro 6 emmisions with just an EGR valve and no DEF or LNT. However, if that's true in real life aswell remains to be seen. I expect ALL diesels will get checked shortly, as now BMW got the attention of the German government aswell for non-compliance
