JHZR2
Staff member
Looking for quality long Allen sockets, ideally with a ball end. Any recommendations?
I have ball end bond his wrenches. I used a box end wrench on them to remove bolts that held my intake on.when i worked in a machine shop, 1990's Bondhus were the ones to buy.
editops, my recommendation is for wrenches, not sockets.
Bondhus has always been a quality manufacturer of these tools. Hazet and Stahlille are almost unavailable at the moment, SK is Chinese owned and Snap on are IMO not the best value or quality for this type of tool.
https://www.amazon.com/Bondhus-3088...771&hvtargid=pla-572502349417#customerReviews
Edit: Simple gifts posted at the same time.
^ Yeah you want a straight allen to get things started. There isn't enough mating/ surface area as it is and the ball end reduces this some more.
I work with a bunch of butchers who cut the ends off of a typical L-shaped wrench then drive them with equal sized sockets. If you have just one size you need for one job, it's a potential solution.
I like that idea, i may try it.Interesting point. May be a better bet to buy a set of L shape bondhus Allens for $16, and cut them and stick them in six point sockets. Then I can have reversible ball and flat end. What’s the downside?
The biggest downside is the bit falling out and dropping down dark places under the hood.May be a better bet to buy a set of L shape bondhus Allens for $16, and cut them and stick them in six point sockets. Then I can have reversible ball and flat end. What’s the downside?
Noted, but not really a risk on the intake manifold bolts of an OM603.The biggest downside is the bit falling out and dropping down dark places under the hood.
All the Snap-on ones I’ve had have come loose and they say we can’t replace them till they break and I hate the loose bits.
Yes they are. 1979 date codes on the ones I have haha. I’m glad they done away with that pin. I think everyone realized it was not a good thing.Are these the roll pin style? I have some updated press fit "hex to hex" Snap-on bit sockets that are older than you that never gave me a lick of trouble.
I will have to buy a coupe of the new ones that I use a lot like 5mm long ball end. My L keys are all Bondus and have lasted as long as I can remember. My only concern with some Snap on stuff is other than the bread and butter tools eg ratchets, sockets, wrenches are they really snap on or a rebrand like the Malco vise grips and Trusty Cook hammers that are rebranded and have a much higher price.While value could easily be argued, Snap-on's latest bit socket offerings are the best I've used. Yes....The whole roll pin debacle was a mess, But I don't think that design has been used since the mid 90's.
I do like Bondhus though.....Just about all my Allen Keys are Bondhus.
Snap on branded and Snap on made tools are usually some of the best in the business and well worth the price.
