More of an observation than anything which I found a little strange.
My Wife has just bought a 2015 Mini Cooper which she is picking up on the weekend.
Being the BITOG'er that I am, I just popped the VIN into the Mini website and downloaded the user manual for no other reason that to look at the oil specification.
The car itself has a small 1.5 litre 3 cylinder, direct injected and turbocharged engine making just shy of 140bhp. Therefore, I was expected it to be specified with LL04 & LL04FE oils. Maybe with an ACEA C3 or C2 as an alternative. However, the manual specifically says you can use LL01 & LL01FE oils in this engine with ACEA A3/B4 used as an alternative...
Clearly no LSPI worries here then! I'll probably end up putting M1 0w40 FS in here at 6 month/5k intervals.
