Lithium Battery - CR2450 vs. CR2450N
CA
I have a Starrett micrometer head that takes a CR2450N battery. Every cross reference I've come across says a CR2450 is equivalent. They're not in the case of this micrometer head.
With a CR2450 installed, the mic is just as dead as if there were no battery installed.
Visually, both batteries are the same to the naked eye; diameter, height, voltage....
So what's the difference between the two?
should be just CR2450...N suffix bears no meaning (other than some fancy buzzwords (e.g. Duracell CR2032 actually bears a suffix called DL2032B).
Q.
I ended up going to a machine tool distributor to get an "N" suffix battery. The mic came right to life when I turned the barrel. I swapped in the non-N battery and it's dead as a door nail.
There IS a difference between the "N" and non-N battery. I just can't figure out what it is.
