Lineman's Pliers
JHZR2
Staff member
New Jersey
Are my favorite and most used pliers. I get it that there is no one size fits all in tool land... Each is for a different job. But if I'm using a gripping tool to hold something in place or (especially) manhandle it out, and it's not fine work necessitating needle nose, nor so large that a tongue and groove type pk ier is needed, these are my choice.
I can't even remember when I used a slip joint plier last, I'll grab the lineman plier first. I actually have two pair I like them so much - a Klein and a channel lock brand pair.
Anyone else use these for diverse jobs besides grabbing, pulling and twisting wire/cable?
Nope. Not because they don't work but because one set is in my turn-out pants and the other is in my "inside the house" toolbox, which gets less use.
You have to try Parrot Jaw Pliers, they are addicting, every exposed bolt looks like they are begging to be gripped by them
Look up Klein D201-7CST .... they're like the Porsche of lineman pliers; lightweight and agile.
At the other end of the spectrum is the Snap-on 59AHLP .... super heavy and beefy.
Nope. You need the 2000 series kleins. They have hardened cutters for cutting bolts.
I am an electrician and don't use my linemans much anymore but that is just the nature of my job. My favorite pair are kleins that I found sitting on an I beam all rusted up that I sandblasted and put the Klein replacement handles on. They are nice and loose.
In that case, the D2000-7CST are the same pliers with hardened knives.
I have the Klein J2000-9NE but use them only for electrical work. Nothing twist heavy gauge wire for wire nuts like these.
For general automotive use I like the Klein D514-8, you might want to look at them, you will change your mind about slip joints.
I never use a linemans pliers. I prefer the slip joint (2 position) pliers because the jaws come out more parallel on larger objects. Needle nose pliers get used on smaller objects.
Trav -- out of curiosity, what do you use for cutting cotter pins ?
Dikes, Klein J228-8 or Knipex 74 21 250
Interesting!
