Exactly. But everyone is different.Every other year if it were mine.
Me? I’m with you. I don’t like to waste resources and time. But there are many things too that I overthink, similar to this thread.
Maybe treat the car as a classic in storage or awaiting restoration and kick it over every week to get oil going? Fuel stabilizer in the tank? Ang. already has it on a trickle charger. Am I on the right track?Launch Google and type the following into Search: can a camshaft rust if a car isn't driven
I'd be worried about mice or other critters getting in and making a nest (apparently the air filter area is a popular spot). This apparently is a common issue with people who store vehicles. Some even have the issue with cars they drive infrequently.Wow ! That is some clean oil for 3yrs/2k. I'm about ready to store an 06' Camry 4 banger for 3 years with fresh oil. Got the car cheap. Fixed it up a bit, and will store it under the house deck ( asphalted). Putting a high quality outdoor cover on it with a Noco 2 Genius hooked up to the battery. The tires will be sitting on these plastic curved things that prevent flat spots. I have no intention of changing the oil, or starting it. Has new coolant/antifreeze also. She's 13 yrs old and can't drive till she 16 in NY.,on a permit license. Question to my BITOG friends : Once car is covered, will be VERY hard to gain access to start it. Is it acceptable NOT to start it for 3 years ????. Will any damage to engine or tranny seals happen ???? Has a new water pump in it also, and new hoses. Enzyme stabilizer has been installed and the tank is full., ran the engine awhile to get the treated fuel to the injectors..... The car will be shaded from direct sun at all times. Anybody who is familiar in this situation, please reply. I have the utmost trust in my BITOG friends![]()
Absolutely this. The car is not designed to be essentially unused, and counting physical deterioration, depreciation, the cost of that oil change and the fact that nothing with that engine has any real collectibility today, you would be literally thousands ahead each year using UBER for those 200 miles. The vehicle is being wasted. Best wishes.get rid of car and use a ride share, or taxi etc,this maybe cheaper than paying insurance, have a relative or friend drive you etc.,,,the rest of the car may suffer by sitting a lot as the tires, transmission battery on and on.
There is no algorithm to keep the fuel fresh at this mileage level.Yearly gets my vote. Something cheap like Supertech oil and filter shouldn’t break the bank. And I probably wouldn’t put anymore than half a tank of gas at a time. Keep it fresh.
I doubt that it is getting sludgy at all.Perhaps Valvoline Restore and Protect would help reduce oil getting sludgey in the OP's situation. What do you guys think?
I’m more concerned about the time get takes get to the next refuel. If the tank was filled today it will take 1 to 2 year before it’s gone. Fuel setting untreated will degrade much faster than oil. A yearly or bi-yearly oil change and fresh 1/4 tank of gas max every six months would be easy and cheap. Which is what I’d be looking for in a rarely used vehicle.There is no algorithm to keep the fuel fresh at this mileage level.
I have a car which right now is going about 200 miles a year, its gone 80 miles since its oil change 6 months ago. average drive is 1.5-3.5 miles. I normally do 10 month oil changes, but should i be changing much sooner due to possible moisture and gas in the fuel? for the first time prior to the last oil change i actually saw moisture on the cap, and changed the oil immediately. it hasnt come back, but i know there is still moisture.
No i cant go take the car on the highway as a solution, so more oil changes is what it has to be if needed. i care about the car and want to take care of it, so that cost is worth it if i should do it every 6 months instead. otherwise i could let the car idle for an hour, but thats not great.
I don’t think that will work. The car is currently using half a tank a year or thereabouts. That gas is sitting any way you slice it. You could use Stabil, or you could empty the tank, but an empty tank will readily corrode.I’m more concerned about the time get takes get to the next refuel. If the tank was filled today it will take 1 to 2 year before it’s gone. Fuel setting untreated will degrade much faster than oil. A yearly or bi-yearly oil change and fresh 1/4 tank of gas max every six months would be easy and cheap. Which is what I’d be looking for in a rarely used vehicle.
Everything corrodes and erodes on a vehicle just setting. Tires, rotors, gasket/seals, plastic parts, etc. I wouldn’t be overly concerned about the fuel tank.I don’t think that will work. The car is currently using half a tank a year or thereabouts. That gas is sitting any way you slice it. You could use Stabil, or you could empty the tank, but an empty tank will readily corrode.
Agree completely. I would say that the owner is actively destroying that car and to your point, is encouraging failure in all kinds of waysEverything corrodes and erodes on a vehicle just setting. Tires, rotors, gasket/seals, plastic parts, etc. I wouldn’t be overly concerned about the fuel tank.
Thanks for asking that question. I have that covered already. The tailpipe will be sealed with steel wool, and I made a nice home for the mice in the rear part of my property. Ran out of $$$$ to complete landscaping, so I had over 600 yds of wood chips placed over the weeds. The chips were free, some spots are 5' deep ( leveled off some of the property as a bonus ). The average depth is 3'. The mice love it !!!! Used to get mice in my 2 sheds all the time...no more. I guess they just make their homes in the chips, and I add chips as they disintegrate. Property looks decent now without the weeds.
Doesn’t much matter.Honda 3.5L V6, the car sees both 100F and 0F
Does for me in my low use vehicles. Diesel longer for sure.So a tank of gas lasts 2 years? Add fuel stabilizer at fill up and change the oil.
Not really.Agree completely. I would say that the owner is actively destroying that car and to your point, is encouraging failure in all kinds of ways
Not really. Rotors can rust over if they get wet. Things degrade from the sunshine in certain climates. But vehicles will stay nicer longer if used and kept out of sun and rain. As someone who has ten cars that get sporadic or very low use, I can unequivocally say that it isn’t as big a deal as folks make out. Sure, it’s essential to get to full operating temperature, and you don’t want fuel to sit too long, but it’s actually a recipe for keeping things nicer and newer longer. So long as you don’t let it bake in the sun.Everything corrodes and erodes on a vehicle just setting. Tires, rotors, gasket/seals, plastic parts, etc. I wouldn’t be overly concerned about the fuel tank.
